WD fuel filter
lminch
06-13-2006 09:25:38
OK So I have my carburator rebuilt and want to prevent further problems. What is the best way to filter the fuel to a metal fuel line. Can I just cut it and add any inline filter from auto store or does it have to be specific for fuel flow. Looking for ideas. Thanks
Steve in N.J.
06-16-2006 18:43:45
 Re: WD fuel filter in reply to lminch, 06-13-2006 09:25:38
We carry the sediment bulbs in stock. Also have a nice little inline fuel filter designed for gravity feed fuel systems. Drop us a line if interested...
Steve@B&B
Henry M
06-14-2006 09:32:01
I changed the fittings at the bowl and the carb to barb fittings and stuck an inline filter that you grab off the shelf at the store in there. It has worked great for me, but the correct police would not approve.
The tank was reall full of trash. so when the motor lugged down and started starving, I pulled the filter and blew through it backwards and put it in for another fill up of trash. After several interations of that it has been cooking great for about a year.
This is on a JD so I don't know if the setup would be compatible with the orange lol.
wdtom
06-13-2006 18:01:36
I know that inline filters made for fuel pump systems can be a problem, sometimes they don't fill all the way and don't flow gas right, however I installed one on my WD anyway, and it has worked perfectly for a couple of years now.
old
06-13-2006 10:58:52
You can add a fuel filter but the ones made for car/trucks will give you more problems then they wil fix. You need to find one made for a fuel system with out a fuel pump, one made for a motorcycle works well.
lminch
06-13-2006 13:44:32
 Re: WD fuel filter in reply to old, 06-13-2006 10:58:52
I am batting 0 for 3. No screen anywhere that I can tell.
old
06-13-2006 14:52:45
 Re: WD fuel filter in reply to lminch, 06-13-2006 13:44:32
Yep a lot of times they get removed instead of cleaned like they should be. I'd replace the sediment bowl assembly and also buy an elbow with a screen on the end of it. Agco dealer should have the parts and or TSC etc
lminch
06-14-2006 05:55:31
 Re: WD fuel filter in reply to old, 06-13-2006 14:52:45
Those are all good ideas. Thanks
lminch
06-13-2006 12:08:38
That is sorta what I was wondering. Do most sediment bowls have some type of a screen? I know mine does not but wasn't sure if it fell out or what.
old
06-13-2006 12:15:45
 Re: WD fuel filter in reply to lminch, 06-13-2006 12:08:38
Well if every thing is as it should be you will have 3 screens in the fuel system. One is in the tank on the sediment bowl assembly one should be up in side of the bowl area and one should be in the elbow on the carb. A lot of times the one in the bowl and the one in the carb are missing.
