WD carb problem?
Hossman
06-11-2006 12:59:02
Fellas, My Pa has a 48' WD that started actin up the other day after plowin a couple acres, it seems to possibly be fuel related but the tractor wont even run without the choke bein on.I know Ive read somthin about this from other guys but couldnt remember all the things to trouble shoot. The main jet came loose last year andwe got it back in adjustment, but this apears to be a different problem. For what its worth the tractor has a zenith carb. Thanks for any ideas, Hoss
Steve in N.J.
06-16-2006 19:05:06
 Re: WD carb problem? in reply to Hossman, 06-11-2006 12:59:02
Hoss, Great advice from Old. Check the screen in the fuel tank which is part of the sediment bulb. It may be plugged cutting off fuel flow. If you do have good fuel flow, we offer carburetor rebuilding services and or carb kits if needed.
Steve@B&B
old
06-11-2006 13:17:56
First thing to do is pull the drain plug from the bottom of the carb and make sure you have a good flow of gas there. If you do then you probably need to rebuild the carb. If you don't have a good gas flow there then pull the line off the carb and make sure you have good flow there. If you do have good flow at the line then its back to the carb if you don't then check the sediment bowl and you may even need to remove the sediment bowl assembly from the tank and clean the inside sceen area
