WD 45 hydraulics
Neil Perrel
06-11-2006 11:07:47
I have a WD 45 and the problem is that the lift arms will not release and go down even when attached to my bush hog mower. The mower will not lower. I have changed the oil and refilled with 20W non detergent oil and adjusted all the settings on the controls i.e. A, B, C, D as instructed. Can anyone give advice on what the problem is and how to fix it? Thank you.
Sid
06-11-2006 21:52:58
 Re: WD 45 hydraulics in reply to Neil Perrel, 06-11-2006 11:07:47
I am unable to send a picture. I will try to explain to you what the problem was when my WD did the same thing. if you have an owners manual it might make it easier for you to understand what I am trying to describe. Above the front end of the drawbar where the big spring is you should be able to see a "drawbar link rod". It is a flat piece that hhas a bend it it that angles the rod up toward the pump. You should also see a slot in the upper end of this rod that fits over a "draft control lever pin". You should see where that lever fits overe a small shaft. What happened on mine was the lever had slipped on that shaft and would not hold it in place. It seems that spring tension on this shaft holds the valves in the raise position. It was telling the pump to lift and when I would push the lever down to lower the equipment it was just moving the lever and not the shaft. I hope you can make some sense out of this and that it is of some help.
jon in IL
06-11-2006 16:05:22
I had the same problem a couple of years ago. I had to rebuild the pump and it has worked ever since. Jon Olson
