need rubber tube from air cleaner to carb wd45
greg mmmm
06-09-2006 11:31:31
Looking to purchase the rubber tube that goes from the air cleaner to the inlet of the carb. If anyone knows where I can get one please let me know.
Hossman
06-12-2006 18:12:17
 Re: need rubber tube from air cleaner to carb wd4 in reply to greg mmmm, 06-09-2006 11:31:31
Greg, Had the same problem last year when I restored my WD45 and I ended up measurig the inlet and outlet size or the carb and breather and simply went to the local autozone and mad em pull some radiator hoses with roughly the same shape and cut the" bend "outa the hose at the correct lenghth worked like a charm now for over a year and even looks original with the right curve in the hose and all! Hope this helps, Hoss
old
06-09-2006 11:57:24
AGCO should have them. If not I use a radiator hose on my WD and WC. works well but of course isn't as good looking as what was there when new
