A-C Garden Tractor
Scott Price
06-08-2006 09:24:35
I just aquired a model 416-S garden tractor.
I am looking for any info on this unit.
I would like to restore it. also would like to find out what accsesory are/ were available for this unit.
Can any one point me in the correct direction?
Thanks.
IA Roy
06-09-2006 19:31:03
 Re: A-C Garden Tractor in reply to Scott Price, 06-08-2006 09:24:35
I have a 416H which must be a couple of years older, someone told me about 1972? I assumed that it was built by Simplicity, but was later told that it was built by Allis. K341 16 hp single cylinder Kohler. Vickers Hydrostat. I only have the Allis 48" deck for mine. The relief valve spring on the hydro was broken and it pulled down terrible under load. It was not available as a repair part. I was able to buy a Simplicity 7016 tractor with a bad engine and did some rigging and put the Hydro (something other than Vickers) in it. I acquired a Sears snowblower that had been converted to a Cub Cadet and then I converted it to fit mine, used it that way for about 4 more years and the balance shaft came out the side of the block. Next door neighbor gave me a 414 with a good engine and tranny problems last summer, so now it has a 14 hp engine. It seemes to handle the blower and the deck fine. Happy to answer questions, but told most of what I know. A friend had an older 12 hp unit with a rototiller. I am sure a blade was available, probably a snow blower also, yard cart, maybe a generator. I built a wooden and plexiglass cab for it and hung a 350 Buick engine block and another 130# of steel for traction. Cut down car tire chains, and it does really good unless I get high centered on snow or off the side of the driveway into the ditch.
daniel perkins
07-27-2006 13:50:39
 Re: A-C Garden Tractor in reply to IA Roy, 06-09-2006 19:31:03
As to those Kohler balance gears..... I take them out asap!! Seen way too many have the retaining clips come off like yours did & get thrown through the block. They do little to stop vibes anyway. On a solid mounted engine like the Allis, the extra vibes are nothing at all. Not all K's will have the balancer gears.
CJ-maybe
06-08-2006 11:46:16
simpletractors.com
