wd vs wd45
Mike in Ohio
06-08-2006 04:37:11
Going to look at a wd45 this weekend. I was looking at Terry Deans book and it shows an almost 1100 weight difference between the two. What is the difference that causes such a huge weight increase on the wd45 over the wd? Thanks alot. Mike
wdtom
06-08-2006 17:37:54
 Re: wd vs wd45 in reply to Mike in Ohio, 06-08-2006 04:37:11
I have to work to get my WD up to 3500 lbs. to pull in the 3500 lbs. class. It is complete but the tires are not loaded. Without a little weight here and there that I have added I think it would weigh about 3400 lbs. There is really no difference that would account for much weight difference between thetwo tractors. Larger rear tires and wider rims, a little, other than that they are about the same as far as what would weigh.
Tramway Guy
06-08-2006 09:09:56
The WD45 had bigger rear tires, they could hold more fluid.
Also, the snap coupler equipment would have been included on the '45, as well as fender extensions.
A little bit here, a little bit there.
John (MO)
06-08-2006 08:31:20
My information shows the WD gas unballasted at 3721# and ballasted at 6313#, shipping was 4000#. The WD45 gas unballasted was 3955#, ballasted 8005# and shipping was 4465#. I've found that just like information that is shared on the web, not all print information is as good as it could be.
John (C-IL)
06-08-2006 05:29:15
Equally equiped there isn't more than a couple hundred pounds different. The 45 probably came with fluid in the tires and possibly a set of weights. The onlt real casting difference is in the front pedestal and the engine differences that would account for only a few pounds.
Mike in Ohio
06-08-2006 05:45:26
 Re: wd vs wd45 in reply to John (C-IL), 06-08-2006 05:29:15
That makes sense.The book shows 3388 pounds for the wd, and 4465 for the wd45. Loaded tires and some weights would make up that difference pretty quick I guess. Thanks alot. Mike
