DANCO BELLY MOWER
Sonny1
06-07-2006 14:47:57
I have a 55 ALLIS CHALMERS CA with a Danco belly mower, however the actual problem is that the rear cylinders don't work, and they don't seem to be original AC equipment. So with that siad I'm asking if anyone know if Danco still exist, and if the cylinders were part of the belly mower set-up?
Thanks, Charles
patsub
06-15-2006 11:39:43
 Re: DANCO BELLY MOWER in reply to Sonny1, 06-07-2006 14:47:57
CA cylinders were designed for the right hand cylinder to operate front implements. lift is designed to allow a delay between the left cylinder and the right. I dought that Danco provided the cylinders. CA cylinders operate with 3000lb. Standard cylinders operate on 2000lb. If your cylinder does not work it should be easy to repair, if the shaft is not ruined. check with an AGCO dealer. They have cylinder repair kits
CHARLES L PARRISH
07-03-2006 03:49:15
 Re: DANCO BELLY MOWER in reply to patsub, 06-15-2006 11:39:43
Thanks, however where is the best place to start to diagnose the problem? Is there an internal pump, because one can't see one on outside of housing.
thanks, Charles
