CA Water pump
Mike in Ohio
06-06-2006 05:43:41
We put a new water pump on dad's ca this weekend. The new pump has a threaded plug in the side of it that leaks a little bit, what can I use to seal it? Will the antifreeze eat through teflon tape? Thanks alot for all your help.You guys help me out alot, most of the time before I even ask the question. Thanks again. Mike
noncompos
06-06-2006 12:51:17
 Re: CA Water pump in reply to Mike in Ohio, 06-06-2006 05:43:41
Ever hear about the guy who formulated an acid that would eat up everything? He would've gotten rich except he couldn't find anything to keep it in...
Texas Denny
06-06-2006 05:50:43
If the threads and plug are good, I'd use teflon tape. The antifreeze will have zero effect on the teflon. As far as I know, the only material that affects PTFE (teflon tape) is hydroflouric acid. Of course, hydroflouric acid affects pretty much everything put a one or two special plastics.
