Valve Clearance on a B
jeffalex2
06-05-2006 17:28:18
The manuals say .010 hot...does that translate to .012 cold?
Dick L
06-06-2006 07:11:24
 Re: Valve Clearance on a B in reply to jeffalex2, 06-05-2006 17:28:18
You do understand that you set the valve clearance before you start the engine and then you warm the engine and re check the valves and re torque the head while warm. You will find that the torque will be less than where you thought it was set. If you are building a house a good rule is to measure twice and cut once. Same kind of rule applies to working on engines. Double check your work. Saves money and time in the long run.
jeffalex2
06-06-2006 18:51:07
 Re: Valve Clearance on a B in reply to Dick L, 06-06-2006 07:11:24
So put it back together minus the sealer on the valve cover, warm it up, take the valve cover off and check it all again?
Dick L
06-07-2006 10:28:39
 Re: Valve Clearance on a B in reply to jeffalex2, 06-06-2006 18:51:07
Yes sir! that is the way to do it. I seal/glue the gasket to the valve cover and do not put dope on the bottom of the gasket. I put a coat of gun grease on a cork gasket but nothing on the rubber/plastic valve cover gasket where it meets the head. Same on a pan gasket. I can then take the valver cover or pan off and on without messing up the gaskets. If the head and block surfaces are clean without paint they won"t leak it tightened properly.
old
06-05-2006 18:33:49
Can't say yes or no on that one. I just set a set of them the other day at .015 when it was cold. I prefer them to rattle a little instead of being to tight.
