Tractor recommendations
Joel B.
06-05-2006 10:49:42
I'm posting this on multiple boards to get the most options.
I have a '44 Ford 2n that I was hoping to use to pull my boat out of the water...not going to happen, not enough weight. This is not at a nice public boat launch, just at the shoreline of my cabin. Would filled tires add enough weight? They used to be filled but I got tired of the corroded valve cores leaking and drained them. I suppose I could fill them with anti freeze but how much weight would that add? How much weight can I add to a 2n?
And finally, what would your tractor recommendation be? I need something short, squatty, gas, wide front (dealing with a hill) and around 4000 pounds and under $5000. I'm guessing on the weight, I know the boat/motor/trailer weighs about 2500 pounds plus pulling it over a lip at the shore and up a slight incline at the lake.
Thank you for any ideas,
Joel B.
J.C.H.
06-05-2006 17:19:54
 Re: Tractor recommendations in reply to Joel B., 06-05-2006 10:49:42
Sounds like a job for a "Winch" equipped toter. Tractor would do good on level ground after the Boat and Trailer are there.3/4 ton Chev 4 whl drive w/454 will do a good job also.
Henry M
06-05-2006 16:34:21
Joel
How about the brakes when you back that 2 N down to the lake?
JMS/MN
06-05-2006 14:45:48
Cheapest thing would be to replace those corroded valve stems and put the fluid back in. Add some weight if necessary. People used to farm with those tractors- 2500 lb is not much of a load.
BCnT
06-05-2006 13:03:53
that 2N should be plenty tractor if its in decent shape...fill tires with plain water if you dont use it during winter months...use a drawbar mounted to tractor...not 3 point.
dej(JED)
06-05-2006 11:51:21
A 2N Ford is way to light to be pulling a 4000 lb. load over a lip and up an incline. You are just looking for trouble with that set up. You can get one of the old IH W6 tractors for around $2000. They weigh in at around 6000 lbs and have plenty of power. A D17 or D19 AC is a good choice also. Their are actually several of different makes that would fit the bill. I would get something that weighs at least 4000 lbs and has a wide front end though.
souNdguy
06-05-2006 12:38:21
 Re: Tractor recommendations in reply to dej(JED), 06-05-2006 11:51:21
He didn't say he was PULLING 4000#.. he said he was pulling 2500$.. wanted a 4000# tractor.. etc...
Soundguy
old
06-05-2006 12:15:09
I think you miss read what he said, I.E. the boat/trailor is 2500LLBS but he wants a tractor that weights around 4000LBS. The 2N weights in around 3500lbs by its self so it has the weight it need but maybe not the traction it needs
Joel B.
06-05-2006 13:26:48
 Re: Tractor recommendations in reply to old, 06-05-2006 12:15:09
Thanks "old". I may be mistaken but I recall the 2n weighs in at less than 2500 lbs.
old
06-05-2006 13:35:47
 Re: Tractor recommendations in reply to Joel B., 06-05-2006 13:26:48
Tractor data book lists the 2N at 3070LBS and that is with out fluid in the tires or other weights on it. So if you add fluid to the tires it would up that by around 300-600 lbs depending on what size tires it has and how much fluid/type you put in
old
06-05-2006 11:09:40
That 2N with fluid in the tires and some weight up front should do the job. I use windshield wiper fluid in my tires, not as heavy as the CACL but also doesn't rust the rims if you get a leak and also doesn't kill animals like antifreeze will.
Ryan - WI
06-08-2006 09:00:53
 Re: Tractor recommendations in reply to old, 06-05-2006 11:09:40
Keep in mind that if you only have air in the tires and the tires go in the water they are actually pushing up against the weight of the tractor. Fill them and then give it a go.
