Roosa Master Pump on Series I D17 Diesel
Tracy Carollo
06-04-2006 18:51:27
I have an AC series I D17 diesel with a fuel pump problem and I could use some help answering a few questions. The ID tag on the pump is missing so I can't list any specifics about the pump it's self. There is a brass rod the runs all the way through the rounded part of the pump housing. I believe there's supposed to be a brass nut on each end of the rod too, but I only have a nut on one side of mine. At some point the rod broke near one of the nuts and rather that replacing the rod, a pervious owner put some rubber filling the hole that the rod normally stuck through and where it could be held in place with the nut. Everything had been working fine for me until I noticed fuel leaking out the side of the pump. Can someone tell me if this rod simply be removed and replace without disassembling the whole pump? Can some provide me with the contact information for a place where I can order this part? I might be able to provide a picture if my description can't identify the part in question.
