WD-45 charging problem
Lamar Hager
06-04-2006 09:57:16
I have a WD-45 and have been unable to get the
electrical system to charge the battery. I got a new three-way light switch & cut out. I wired
them according to the diagram in the service manual. I had the generator checked and it is produces up to eight volts on the bench. I have made sure that the generator well grounded at its
mounting and that the wiring box is grounded to the battery box. All the wires are in good condition. It still won't charge either in the light switch off or in the charge position. The
ammeter show discharge when the lights are on both when the engine is running or stopped.
Anybody have advice on what is wrong?
steve(ill)
06-04-2006 18:54:15
 Re: WD-45 charging problem in reply to Lamar Hager, 06-04-2006 09:57:16
ground the F terminal of the generator. if it charges, the light swith resistor or ground wire is the problem.---- jumper around the two terminals of the cutout, if it charges, the cutout is not working.
RandyN
06-04-2006 17:39:59
Did you polarize the system? You mentioned a cutout and a three-way switch. In that case, with everything hooked up, including both battery cables, briefly touch the two terminals on the cutout relay, (BAT) and (GEN), with a piece of wire.
Check out the generator articles in the links to the left..they are wonderful.
RandyN
RandyN
06-04-2006 17:43:06
 Re: WD-45 charging problem in reply to RandyN, 06-04-2006 17:39:59
Also consider the position of the third brush. If it is all the way "down", it won't put out any amperage....or at least not much of anything.
RandyN
BCnT
06-04-2006 11:44:17
8 volts is ok but how many amps is it producing?try this...fire tractor up and idle up to about 1/2 throttle with lights on...ground field terminal and see if lights brighten up...if they do the generator is working ok.
check and see if you can turn generator without belt moving...i've seen worn/glazed belts slip even tho you could pluck em like a banjo.
