WD45 two-way hydraulics?
Tony Z
06-04-2006 06:51:39
Hi Everyone,
I have a WD45 and I recently picked up a small round baler on the cheap. However, it needs two-way hydarulics to work. Does anyone know of a way to make the hydraulic system work short of putting a pump on the front and new tank? I was really just looking to get by this summer and then do that over the winter. Thanks!
Tony
Tony Z
06-05-2006 07:27:30
 Re: WD45 two-way hydraulics? in reply to Tony Z, 06-04-2006 06:51:39
Thank you both for responding. I will see what I can cook up this week and if I run into problems, I will ask you experts here. :-) I am just a beginner farmer.
Tony Z
Jerry (mo)
06-05-2006 07:03:29
I made a webpage when a did mine
JMS/MN
06-04-2006 08:14:44
Hook a two-way valve into your tractor remote and run the return line back to the reservoir. Return can go into the filler cap or up through the drain plug. If you have no remote outlet, add one, connecting it to the third port on the top of the hydraulic pump- two ports are used for the lift cylindedrs. You'll need to activate the hydraulic lever to push oil to the add-on valve. Not the handiest, but it does work.
