Carb
glider
06-04-2006 05:22:46
Wd 45, carb rebuild kit off the shelf at TSC. The tractor runs great for a while , then I have to adjust the "load or power screw" good...then adjust...etc.... Should I buy a new load adjust or look for something else? P.S. everything looks to be clean.
BCnT
06-04-2006 09:25:07
 Re: Carb in reply to glider, 06-04-2006 05:22:46
unscrew the power needle and stretch the spring some...i've run across some kits lately that dont have the best springs and adjustments move around from vibration.
Henry M
06-04-2006 05:28:06
glider
I would take the plug out of the bottom of the carb and turn the gas on and watch it for a while to make sure the flow doesn't slw down after the bowl of the carb drains down. May be a restriction in the gas getting to the darb?
