Need WD-45 power adjust rim
Kelly MT
06-03-2006 09:32:26
I'm looking for a good power adjust rim for my WD-45 Diesel. Know of any? Anyone ever repair a rusted and cracked (at the tube stem hole) rim? PK
wilson
06-03-2006 17:26:51
 Re: Need WD-45 power adjust rim in reply to Kelly MT, 06-03-2006 09:32:26
used to be a wd 45 setting behind thompson falls vet south road several housed been a while since i was there though
HenryM
06-03-2006 14:58:02
A common way to do the valve stem repair is to (if you have a donor rim that is close) cut a chunk out of the donor and put it in the bad spot on the one you want to repair.
Then you can fabricate another valve stem hole if needed.
Sid
06-04-2006 21:05:06
 Re: Need WD-45 power adjust rim in reply to HenryM, 06-03-2006 14:58:02
"Then you can fabricate another valve stem hole if needed." Gee, all these years I been drilling them holes. Next time I will try to fabricate one if I can keep from getting in a hurry. I know it sounds like a smart alec but that just kind hit me funny.
