AC 170 tranny oil
bake545
06-02-2006 12:43:33
Can someone tell me what type of oil goes in a 170 tranny? The service manual only mentions a special AC gear lube but not the weight of the lube. I've seen "Universal" Tractor tranny fluid in 5 gallon buckets at autoparts stores but wasn't sure if that was the correct fluid or not. Thanks!
bake5454
06-05-2006 16:27:08
 Re: AC 170 tranny oil in reply to bake545, 06-02-2006 12:43:33
Thanks for the responses guys. I don't recall there being a number. Can you buy the fluid in anything besides 5 gallon buckets?
Sid
06-02-2006 18:40:22
If you take that number and go look at a bucket of universal fluid, you should find that number on the bucket it will be marked as to what specs it will meet. The universal fluid is what I use. It is also what the dealers sells me. Every brand of Universal that I have looked at meets the AC specs for my tractor anyway. I do not think you will find a weight of fluid like in the old transmission gear oil. Hope this helps.
JMS/MN
06-02-2006 12:49:06
Can't tell you from memory, but likely what the D17 had. All that is in the operator manual- not the service manual. I know that doesn't make the most sense, but everything the operator needs to know about 'servicing' the tractor is in the operator manual. Service should really be called a repair guide.
