Allis 7050 won't move
Rick Mandl
06-01-2006 20:29:58
Sunday I used the tractor and parked it when I was finished, no problems. Monday when I started it up everything appeared to be fine, then I put it in gear and it just sets there. It feels like the shifter lever is going in and out of gear with or without the clutch, with the same results. NOTHING anyone have any suggestions???
4478
06-03-2006 19:08:29
 Re: Allis 7050 won't move in reply to Rick Mandl, 06-01-2006 20:29:58
does your pto power steering and hydrualics work?
if not then your torque limiter gave up. this happened to my 7060 with powershift. 800 dollars for parts and labor + trucking, not too bad. ray
glr62
06-02-2006 19:04:34
Also check range trans lever cable, that is hi-lo park lever.
BCnT
06-02-2006 08:34:00
i'd check fluid level again and filter [if there is one]
CAL (KS)
06-02-2006 04:36:26
check to see if you trans-pressure light ever goes out. if not you have hyd pump related problem since 7000 series have wet clutch and brake.. no pump = no move
if you can feel slight grinding when shifting i would say start by checking hyd pump. it will grind because of the small amount of friction in the non pressurized clutch but when put in gear it will just slip
if i recall 7050 is maroon belly only? so shifter is on floor and no cables
good luck
06-02-2006 16:20:33
 Re: Allis 7050 won't move in reply to CAL (KS), 06-02-2006 04:36:26
when I shift the shifter, I feel it clicking into the gear but I feel no grinding. It's like you were shifting the gears with the engine off. Someone told me today that he thought the Main Power Director houseing had stripped out and a new one was about 2000.00. Im going to be their this weekend and will look into the fluid levels and filters. I'm not sure which light it is but I know one of them never goes off. The scarry part is the guy who works on the tractor is the one who said not to pay any attention to that light, they all do that. I am new to Allis tractors, and I appriciate your advice. I'll let you know what I find out. The mechanic is booked for 2 weeks.
