Model B Rear end
DavidKittle
06-01-2006 15:22:17
Hello;
I have a 1951 Model B on which I have replace both rear grease seals. I Noticed that on the right rear there is a grease leak, but it only comes out after the tractor is parked after running it a few hours. I removed the wheel and found a shiny spot where the hub rubbed on the seal. I drove it in further. Is this the cure?
Also, how often should the rear drive oil be changed? Mine is pretty darn black.
Thanks
steve(ill)
06-01-2006 18:17:06
 Re: Model B Rear end in reply to DavidKittle, 06-01-2006 15:22:17
pounding the seal in a little can not hurt. the inner ring the seal runs on could have grooves and cause some leaking in the future.--- also, the splines can be worn a little, letting the hub slide on further and then contact the seal. i have had the hub drag on the housing and actually have to grind 1/8 inch off the back of the hub so it would not hit.--- the oil is 90 wt gear lube. probably 60 years old. take the sheetmetal half moon pan off the bottom, clean it up, reinstall and add a couple cups of new gear lube. that would help. you can make your own gasket, or just use a good bead of RTV.
Dick L
06-01-2006 17:35:00
 Did You Have The Axle Out?? SORRY in reply to DavidKittle, 06-01-2006 15:22:17
Forgot the picture!
It might have looked like the one on the right instead of the ones on the left.
third party image
DavidKittle
06-15-2006 05:56:29
 Re: Did You Have The Axle Out?? SORRY in reply to Dick L, 06-01-2006 17:35:00
Hello:
Would you know where I could buy the axle spacer? I tried to find one but no luck.
Thanks a lot.
Dick L
06-01-2006 17:33:21
 Did You Have The Axle Out?? in reply to DavidKittle, 06-01-2006 15:22:17
