Wiring CA
Phil Hengesbach
06-01-2006 06:11:37
Had a dead short that melted the harness in the Switch box. Need Ideas on how to proceed. Slso is there any way to know if The switch and the Amp gauge are still good, hte short did not burn into either one.
Steve in N.J.
06-05-2006 04:28:17
 Re: Wiring CA in reply to Phil Hengesbach, 06-01-2006 06:11:37
Phil,
We offer a complete 6V replacement wiring system for the B,C,CA machines. Drop us a line if interested..
Steve@B&B
Phil Hengesbach
06-08-2006 09:52:26
 Re: Wiring CA in reply to Steve in N.J., 06-05-2006 04:28:17
Yes I"m interested I need a complete harness for a CA if you have one. I tried your email but it didn"t go through.
Texas Denny
06-01-2006 06:31:42
Phil, I have a wiring diagram for a CA. Send me an email and I'll send you the diagram. You can test the switch with a volt/ohm meter set to the ohms position. The amp gauge needs quite a bit of current to function so the only way I've found to test it is use in a system. There are no outward signs unless the meter is pegged to the discharge side.
Phil Hengesbach
06-01-2006 06:37:35
 Re: Wiring CA in reply to Texas Denny, 06-01-2006 06:31:42
My eamil through my work is very fickle about sending to peole outside the system. Security blah blah blah. My email is [email protected] Make the subject tractor history and I Should recieve it no problem. I can reply upon reciveing it. Thank you for your assistance.
