AC-CA no power
rkbell OKL
05-30-2006 13:00:04
Was bushhogging with my AC-CA and suddenly lost power to the back wheels. The main clutch seems to be fine. don't know enough about the power booster, to know if that is the problem. When the trans is in any geer the back wheels turn like they are in neutral.
Wild Bill
05-31-2006 05:50:02
 Re: AC-CA no power in reply to rkbell OKL, 05-30-2006 13:00:04
rk, it is the hand clutch in the right axle housing. there is no adjustment for you tomake it work again, it has gone bad. There are a couple of things that you can do, the easiest is to replce the hand clutch and half shaft assembly with a straight axle from a c or a b, or you can bolt the havlves of the clutch together, but I don"t recomend that. Email me if you need an axle, I think I have a couple.
Wild Bill
05-31-2006 09:54:36
 forgot my email! in reply to Wild Bill, 05-31-2006 05:50:02
email is open on this reply
Texas Denny
05-30-2006 15:03:07
If you have power to the bush hog, the main clutch is OK. Though it could be a number of things, I'd check the clutch in the right rear axel housing first. Does the hand lever still feel and act as it always has? If there is a change in the way it feels, this is first place to look. If the bush hog doesn't work (no pto or hydraulics), I'd suspect the main shaft. But if that is the case, you'd have no way of knowing the main clutch is OK.
