Allis C runs now. Part Who know but any way
old
05-29-2006 13:01:58
Well if you guys remember back a month or so ago I was working on a C. Well up till yesterday it was running good and then all at once #2 cylinder got woter in the cylinder. Same one I put that sleeve in, other then that it purrs like a kitten. So I'm now working on another C engine I have to see if I can get it to run and if I do and it runs well I'm going to swap the engines. I'm tired of messing with that sleeve and the leak problems.
steve(ill)
05-29-2006 18:34:43
 Re: Allis C runs now. Part Who know but any way in reply to old, 05-29-2006 13:01:58
normally one would expect a bad head gasket, or liner not set correctly in the block. other options are a cracked head between that valves that is not real visible
old
05-29-2006 18:41:59
 Re: Allis C runs now. Part Who know but any way in reply to steve(ill), 05-29-2006 18:34:43
This is one that caused me problem a few times. First sleeve I set in sat low in the block and didn't hold as far as the head gasket then this one sat about right but I guess it wasn't all the way down and now has started to leak. I did get the other tractor engine to start today but it has a rattle in the engine so I now need to pull the oil pan and make sure it doesn't have a loose rod bearing. Sure wish these Allis C would just get with the plan and stop makeing me work to get them to do what they where made to do.
