Allis B front oil seal
mrbilman
05-29-2006 05:33:35
The front oil seal on my B is leaking. Does anyone have experience changing the seal? What kind of seal is it? Where can I get one? And the basic steps to change it. The I&T manual says it can be done without removing the timing gear cover (if you are very careful) but doesn't really tell how to do it.
Thanks,
Bill
steve(ill)
05-29-2006 11:07:52
 Re: Allis B front oil seal in reply to mrbilman, 05-29-2006 05:33:35
block or jack up front end at the rear of the the engine. lift front wheels an inch off the gound. remove hood, radiator, and front radiator mount to motor. lower alxe an inch. pull the front crank pulley off. i would lsuggest you remove the front cover and install the seal on the bench, then recenter the cover over the crank with the seal already in it. the seal is rubber oil seal, i think two types depending on what year you got. available at AGCO.
mrbilman
05-29-2006 13:54:24
 Re: Allis B front oil seal in reply to steve(ill), 05-29-2006 11:07:52
Thanks for your proceedure. Will the hole that the wishbone bolt goes thru the bell housing have enough slop to allow the axle to drop an inch or will I have to remove it?
steve(ill)
05-29-2006 18:38:18
 Re: Allis B front oil seal in reply to mrbilman, 05-29-2006 13:54:24
you might have enough slop to let it hang, bu if you take off the rod to the gear box, ot dont take much to just roll it out the front. i have two 3 x 3 angle irons with feet, that i bolt with two 5/8 bolts on each side of the bell housing and holds the front end up and inch. i just roll the front end out to get out of the way. sounds complicated, but you wil be supprised how far you get in 3-4 hours.
