Allis B Wheel Seals Inner Bearing Installation
Toby Wellborn
05-28-2006 19:47:04
How is the best was to install the front hub seal onto the spindle of the Allis B?
After the front hub inner bearing has been packed with bearing grease is the bearing just driven onto he spindle with a brass drift?
Thanks for any help out there!
1755
05-30-2006 14:33:01
 Re: Allis B Wheel Seals Inner Bearing Installatio in reply to Toby Wellborn, 05-28-2006 19:47:04
Find a pise of pipe the right sise and carfuly tap the seal on the spindel then put the bearing rase on
Pappy
05-28-2006 21:53:52
I am not an expert on Allis Chalmers, but I have not seen a front wheel that had to be driven on.
We pack the bearing, install the seal and slide the wheel on. If your spindle is damaged, you might have a problem with this proceedure.
