wd45
dennis hogan
05-28-2006 19:20:02
has some one out there put a 6 cylinder moter in a wd45 be for if so email me
Kent of SW MO
05-29-2006 05:42:13
 Re: wd45 in reply to dennis hogan, 05-28-2006 19:20:02
I have a picture somewhere of this. I have NEVER done this but I understand the G-230 power unit from an A Gleaner is almost a bolt in except for the need to lengthen the frame rails, steering shaft and hood.
Kent
Tramway Guy
05-29-2006 10:21:14
 Re: wd45 in reply to Kent of SW MO, 05-29-2006 05:42:13
You don't lengthen the frame rails, only move the radiator forward. Thus the longer hood.
It is much easier if you already have all the parts from a WD45 Diesel, since that was almost the same basic block as the 262 engine.
dennis hogan
05-29-2006 06:58:09
I am putting a gleanerA 262in a wd45 would like some pic or some in put
Dennis hogan
05-31-2006 16:37:52
 Re: wd45 in reply to dennis hogan, 05-29-2006 06:58:09
I was told it was a 262 gleaner a I would like some pic to make sure.I bught a govenor for a 190 ac does not work but a governor from a d19 lookes like it will if I have pics on how the linkage hookes up so i can hook this one up
Dennis hogan
05-31-2006 16:33:14
I was told it was a 262 gleaner a I would like some pic to make sure.I bught a govenor for a 190 ac does not work but a governor lookes like it will if I have pics on how the linkage hookes up so i can hook this one up
Kent of SW MO
05-30-2006 05:38:38
I did not know the G-262 power unit was used on the Gleaner A. I thought the G-230 was used on the A. My Gleaner C-II uses the G-262 power unit.
Kent
