WC- the modified handcrank/hydralic pump
kwahl1
05-28-2006 19:09:17
My WC/WD has a different set up on the hand crank and I have it all broke down with pieces I'll have to replace because I got a little rough beating it apart.
The hand crank shaft is about 16" long from where it comes out of the engine, thru a pulley (altanater),thru a chain looking pully, thru the large steel thing(7")(holds front end) and about 4" that the hydralic pump fits onto the end. The chain pulley is my mystery. It's two gears, butted together and held in place by a double chain. Getting the spring clip off the chain was easy but ther is no room to know out the "Master link" as the main pulley is in the way. Hence, beat the crap outta the link to break it. Now I'll have to find a chain and figure out how to put it together. Anyone out there seen this set up? I have photos. contact me at kwahl1@sbcglobaldotnet for those. Now I start the hard part, still trying to get the engine unstuff and now it's an overhaul.
Ken
Kent of SW MO
05-29-2006 05:38:18
 Re: WC- the modified handcrank/hydralic pump in reply to kwahl1, 05-28-2006 19:09:17
What you have is a chain coupler the someone added when they add the hydrulic pump. Industrial supply places have a larger selection of the couplers. Some models of Olivar farm tractors also used them between the engine and transmission.
Kent
shakey
06-11-2006 18:41:14
 Re: WC- the modified handcrank/hydralic pump in reply to Kent of SW MO, 05-29-2006 05:38:18
do u have any pics of this front mount pump? if u do can u send them to [email protected]..??? thanks
