Starter grind on a C
Richard G.
05-27-2006 08:58:29
When engaging the starter on an Allis C, Sometimes the starter engages fine and other times it seem to grind against the ring gear. Any thoughts?
Richard
Richard G.
05-30-2006 04:51:31
 Re: Starter grind on a C in reply to Richard G., 05-27-2006 08:58:29
Found the apparent problem. Looks like the weight on the bendix broke off the starter gear.
old
05-27-2006 09:20:25
You probably have some bad/worn teeth on the flywheel ring gear. I'd pull the starter and have a look at them. I had the same problem till I changed my flywheel when I was redoing the engine in my C
