Are my hoses connections correct????
Craig in MO
05-27-2006 08:42:00
third party image
The manual is not clear or I cant read. The rubber hoses in this picture go to my rams and the metal line is the rear aux connection. Are they in the right places? Thanks
Butch(OH)
05-27-2006 19:18:17
 Re: Are my hoses connections correct???? in reply to Craig in MO, 05-27-2006 08:42:00
Yes it does matter how thay are plumbed and your is right. The hold valve only works on the front two holes. Little known fact that when corretly plumbed the lift arms hold on one cyliner, the right one. In the slight chance that you use a mounted cultivator being plumbed correcly also allows for the front gang to raise and lower before the rears.
JMS/MN
05-27-2006 08:57:04
Do you know that you are missing a spring? Hooks into the hole on the hand clutch cover, then to the hydraulic linkage.
JMS/MN
05-27-2006 08:45:37
Yes. But it doesn't matter- it is a common area that all three ports tap in to. That's why your lift arms raise up before the remote has power.
