torque specs-wd45 manifold
uniqueuponum
05-27-2006 05:56:35
could someone please give me a torque spec for a wd 45 manifold Thanks Rick
Jerry Coulter
05-27-2006 09:09:54
 Re: torque specs-wd45 manifold in reply to uniqueuponum, 05-27-2006 05:56:35
The factory service manual shows 20 ft lbs torque for the WD-45 manifold stud nuts.
Texas Denny
05-27-2006 06:14:19
I couldn't find anything about these torques in the IT manual for the 45 or in the one for the D-17. But I did find in the C repair manual and in the CA repair manual that the torque spec is 20 Ft Lb. I believe that the bolt size is the same between the two engines (3/8 -16), so I would expect the torques to be the same. Maybe someone else has data.
Are all of the manifold openings at the same level? I've had to machine several because they were not.
