Carbereator Gaskets on '53 WD
Will Herring
05-26-2006 16:31:05
I know that there are two gaskets that go into the carbureator (one up higher where it goes into the manifold, and one between the two halves). Do tractor supply stores have the ability to get me these parts without me having to buy a kit (because I cleaned it out, and it just needs the two gaskets)?
Also, are there easy ways to get two new radiator hoses for the water coolant system and an air hose for my tractor, or should I order parts from Agco or wherever?
CH
05-28-2006 11:42:42
 Re: Carbereator Gaskets on '53 WD in reply to Will Herring, 05-26-2006 16:31:05
I have just the gasket kits email me and let me know what carb you have and the carb number
Robert in MO
05-27-2006 07:13:38
I don't know if you can get the gaskets separately or not. The radiator hoses are 1 1/2" straight hose. You will need slightly less than 18 inches, then cut to match the old ones.
Good Luck,
Robert
