WD Brake pivot pin HELP
James Herrman
05-23-2006 00:16:00
Am replacing the brakes on my WD and need help on removing the lower pivot pin. I had to burn a section out in order to drive it thru the housing (finally got it broke loose) and now have a problem getting the inner part of the pin loose. Have tried heating it and WD40 and trying to turn it with a chisel. Any help would be very much appreciated. As you all know, not much room in there.
James Herrman
05-24-2006 21:25:44
 Re: WD Brake pivot pin HELP in reply to James Herrman, 05-23-2006 00:16:00
THANKS for the help. Got it out today. Heat and PB Blaster in the right places. Managed to bend the ears on the lower part of the brake shoe and melted one ear in half, but will be able to fix. One side down and with the experience I gained from you guys should make the other side easier. Thanks once again.
Phil Auten (TX)
05-24-2006 06:18:56
First, lose the WD40 and get some PB Blaster (WalMart) or Kroil (link below). WD40 is not a penetrant and won't do much for loosening rusted together parts. Soak well in either of the two penetrants mentioned and you'll be amazed!
James Herrman
05-23-2006 11:51:10
THANKS for the reply. Will do what you suggest. Worked until 10 last night and am getting to go at again, after getting my oxygen tank refilled. Of course that is cheap. Once again, thank you for your time. JIM in ILL.
Butch(OH)
05-23-2006 08:16:02
I had to cut one of mine same as you and it was a bear to get the rest broke free from the brake band and pivot parts, it was not that tight in the inner housing as the hole is oversized some. Try prying the whole mess outwards with a bar through the bottom hole, if it moves it is of course not stuck in the hole but in the band and pivots and you need to concentrate your heat and other efforts there. If it is stuck in the inner housing try knocking it in with a punch from the outer hole. good luck
