D17 brakes
Hossman
05-21-2006 16:55:34
Ok fellas I know someone out there has the trick for this problem, recently purchaced a series 1 D17 58' and have no brake on the left side after inspection theres no brake pads left.Now the million dollar question, whats the trick to get that @#$!% shoe anchor pin out?? I tried a 5ft. railroad bar to pry it out with no luck so I figured I'd go by the I.T manual and drill an tap the pin and use a slide hammer on it well I cant even get it to drill ,its like the pin is titanium or somthing. I even had my pa pryin on the drill with a 6ft. 2x4 while I layed under tractor and held drill in place and sqeezed the trigger. Any suggestions would be very much appreciated thanks a bunch, Hoss
Manfred Schreyer
06-12-2006 18:39:26
 Re: D17 brakes in reply to Hossman, 05-21-2006 16:55:34
I just got done replacing my brakes and had the same problem. After taking the final drive unit off it seemed impossible to get that pin out so what I did was i took a dremel and cut the brake bands off of the pin and used a pipe wrench of the top hole (where I took the cover off of the top) and used that to slowly twist that rod and pull it outward at the same time. The rod is very hard and the pipe wrnech didnt want to grip very well so I used a big screw driver and wedged it in the part of the pipe wrech where you adjust it in order to force the claws together more.
Someone was definately not thinking when they came up with this design!!
Kevin LA-CA
05-22-2006 19:22:56
I am not sure if D17 is like WD... but I welded a piece of 3/4" thread rod to the end. I slipped a pieces of well pipe over the thread rod, a few large washers and a 3/4" nut. Used a wrench to turn the nut, to pull the thread rod, to pull the pin. Worked well, but needed to be a better welder. Was able to save the pin with a little more welding and filling.
Hossman
05-22-2006 18:07:29
Fellas, Thanks a bunch for the ideas, as usual you guys came through, Ill tear into it first day I have a chance. Thanks alot guys! Hoss
JMS/MN
05-22-2006 07:49:45
One way is to get a piece of quarter by two steel, 89-10 in ches long. Drill a 3/4 inch hole near one end. Weld that onto the brake pin. HJeat of welding helps loosen the pin. Also apply some candle wax to the casting as it cools- it seeps into space between the pin and casting. Now you have a hnadle you can beat on with a hammer, rotating the pin. You can also remove the brake cover and douse the whole area with solvent. The pin sticks into a second hole inside the housing which is not accessible from the outside.
JMS/MN
05-22-2006 07:52:30
 Re: D17 brakes in reply to JMS/MN, 05-22-2006 07:49:45
8-10 inches long- missed it on the proofread.
Warren Jerome
05-21-2006 23:58:50
Man, you guys are good.
Texas Denny
05-21-2006 19:21:02
It isn't the only way, but this what I did on my 60 D-17. I put a hydraulic jack under the differential case on the side in question. I jacked it up until most of the weight was off the tire. Then I loosened all the bolts that hold the axel housing to the differential. I took all the nuts completely off and then removed the lock washer and put the nuts back on with an 1/8" clearance (one at a time). Then I jacked it up a little more and let it down a little to put some weight on the tire. By alternately raising and lowering, I eventually (only took a few minutes) was bale to get a screw driver in between the differential and the axel housing and push the axel housing off the 1/8". Used a liberal amount of penetrant lubricant. But by then this pin was loose! You may need to retighten the nuts and repeat the process but it should do it without damaging the pin.
