WD bracket identity help????
Craig in MO
05-21-2006 16:19:15
third party image
As you can see I am busy tearing into my new WD tractor. And I found these brackets behind the wheels. Anyone know what they might go to?
Perplexed
wdtom
05-23-2006 17:36:55
 Re: WD bracket identity help???? in reply to Craig in MO, 05-21-2006 16:19:15
I don't knowwhat the brackets are. However I see form the picture that the seat shock/spring has a cruved,slotted mount under the cruved seat support. This, if I remember right from reading my parts manual, was a 45 change. You may have a 45. I know it could have been swapped on over the years too. You at least have a latter WD, curved shift lever, distributer, stamped clutch foot pedal, tall head,snap coulpler. Again, some of these could have been added over the years, but together they point to a late wd or 45. Have you check numbers?
Eldon (WA)
05-22-2006 20:46:09
Give us the casting number so we can look it up.....I don't think the mower brackets went on both sides, and that looks way to HD for a counter-ballance spring bracket.
BudH
05-22-2006 11:53:53
The brackets are part of a counter spring system for a no. 7 rear mounted sc sickle mower. There are other parts which attach to the brackets to help balance the mower.
BudH
05-22-2006 11:50:26
The brackets are part of the counter spring assembly for a no. 7 rear mounted mower. There are other parts which attach to it to help balance the mower.
Tramway Guy
05-21-2006 18:47:18
Perhaps for Arps Half-tracks?
old
05-21-2006 18:11:28
Can't help with what they are but if you find you need parts I have a WD parts tractor on the place. E-mail is open and also in the web page theres my phone number
Craig in MO
05-21-2006 16:20:13
third party image
Just another angle
Jerry Coulter
05-21-2006 19:35:56
 Re: WD bracket identity help???? in reply to Craig in MO, 05-21-2006 16:20:13
Can you tell me what those numbers are? If it is an AC number, I might be able to look it up.
