'39 B brake band
maricopa
05-21-2006 15:29:32
How involved is changeing a brake band and cleaning drum....
Dick L
05-22-2006 05:18:55
 Re: '39 B brake band in reply to maricopa, 05-21-2006 15:29:32
If you have a belt sander with the right shape you can turn the hub and clean up a brake drum. The one I cleaned up with a belt sander I did not try to remove all grooves just gave the high area a new metal look.
Andrew Z
05-21-2006 17:12:36
Its not fun, I just got doing mine and its a good afternoon project. If you want to clean the drum off the tractor you will have to remove the final drive. Otherwise you can do it in place, need to remove the fender and side rail tho. Good Luck Andrew
