D-15 hydraulics
Rick B.
07-06-1998 05:09:57
Using D15 w/Snapcoupler & heavy duty 3pt adapter to run a Bush Hog 306 cutter. When tractor warms up, the hyd. system lifts the cutter about 2/3 of the way up with motor running @pto speed. OK, I said, the pump is getting lazy, cutter is heavy, oil hot & thin etc. Then I noticed with tractor @ idle, lift goes all the way up. Then on the next cycle with tractor at speed, only 2/3 lift. Any ideas from the Allis experts out there? I have hyd. experience (not AC) and all books for this unit. is there a suction screen or filter on this system?? Controls seem to be in adjustment.
