WD
MN Bob
05-20-2006 04:59:43
Well I did it again, small leak around the pump to rad hose, bought new hose, pulled the pump and installed. Yep, the pump leaks and it "looked like" the hose. Pulled it apart again, the manifold gave up. I need a decent manifold and would like to get just the seal for the pump. Nothing wrong with the bearing etc. Any help?? I seen ebay etc, looks like 65 to 85 for a W/P kit to 125 for a new one. Manifold is 100+. Cant do anything on the cheap anymore. Bob
Texas Denny
05-20-2006 16:46:08
 Re: WD in reply to MN Bob, 05-20-2006 04:59:43
I've rebuilt a two WD's, a D-17, a C, an Oliver 70. It isn't easy but you can do it if you have a good machine press and the sealing surface inside the pump is OK. I had good luck with all of mine. They will all leak a little for the first 10 or fifteen minutes of running. The Oliver took about 30 minutes but it eventually worked.
Jerry Coulter
05-20-2006 05:33:20
You better go for a new or rebuilt pump. The seal assembly includes a carbon piece that rubs against the pump body. Unless you can machine the body surface smooth, a new carbon will leak. When my dad had his AC dealership, we never had any luck trying to rebuild those pumps.
MN Bob
05-20-2006 05:55:12
 Re: WD in reply to Jerry Coulter, 05-20-2006 05:33:20
Thanks Jerry, I guess I remember when we used to "rebuild" water pumps with oakum and gaskets. May as well bite the bullet and spend some of the wifes hard earned money, She says she is working to support my farming habit. Bob
