D17 hydraulic question
charlieLCDR
05-19-2006 17:31:28
Want to change hydraulic oil in my series III. It apperars to have a hydraulic filter, at least there are two filter on the right side of engine. I assume the rear one is hydraulic. Also I believe the plug to the left of trans shifter is the hydraulic filler plug. Which drain plug underneath drains the hydraulic fluid?
Also can anyone provide me with a replacement filter number?
One mor question, What does the knurled knob next to the remote hydraulic connection do?
Thanks for any help!!!!
JMS/MN
05-20-2006 18:26:22
 Re: D17 hydraulic question in reply to charlieLCDR, 05-19-2006 17:31:28
The AC mfgr number for the filter is 70237000- same as the engine oil filter. www.agcocorp.com for a dealer locater. You'll find answers to all your other questions in the operator manual, including an explanation for using the (knurled) transport valve.
charlieLCDR
05-21-2006 05:30:17
 Re: D17 hydraulic question in reply to JMS/MN, 05-20-2006 18:26:22
Thanks for filter info!
I have manual on order but wanted to change hydraulic oil before mowing hay because my oil looks milky. Still not sure where to drain the hydraulic oil at.
JMS/MN
05-22-2006 08:00:19
 Re: D17 hydraulic question in reply to charlieLCDR, 05-21-2006 05:30:17
Drain plugs are underneath the tractor, left side, on pressed steel sump covers. About inch in diameter. One under the PD clutch, one about a foot to the rear. Differential drain plug is in the exteme rear of the tractor, bottom side.
