Checking for spark on mag. ('39 B)
Chris (OR)
05-18-2006 08:30:08
Is there some neat trick to checking the spark on a hand cranked motor with a magneto? I couldn't get my '39 B to start last night. Normally it's the first or second crank to get her to start. But is there any way for one guy to crank the motor over by hand and hold the spark plug against a grounding point and watch the gap to see if you have spark? Do I get a pair of vice grips and clamp the plug against the radiator housing and have it burn holes in my paint where it grounds?? There has to be a way for one guy to do this....
Thanks
Chris Horn
Scappoose Oregon
kingmondo
05-21-2006 07:18:38
 Re: Checking for spark on mag. ('39 B) in reply to Chris (OR), 05-18-2006 08:30:08
Use an electric fence tester to check for spark. Place one end on the end of the plug and put the other in the spark plug wire. If you place it right you can see the spark on the tester as you crank. Won`t work if plug is bad.
chalmersbob
05-19-2006 19:17:22
i bought 2 clips made for a battery charger (the larger type) and connected them together by the handles. i put a plug in 1 clip and clip the other one to a metal surface. now both hands are free. Bob
old
05-18-2006 19:33:10
I did that just the other day on a C. All I did was hold the #1 plug wire close to the block and then turned it over with one hand. Thats the nice thing about the impulse it trips and you either have spark or you don't have spark.
JMS/MN
05-18-2006 14:27:12
REALLY long plug wire. Gripped in teeth will work. Or held close to a (tractor) body part.
Rod (NH)
05-18-2006 09:26:57
Chris,
It won't burn any holes in your paint but you do need to ground the plug in some way. You need to find a ground area that is free from paint. I usually take out all four plugs just to make it easy to crank the engine over slowly. Use the #1 plug and plug wire and either lay the plug on the mag body such that ground contact is made or use a wire with clips to get a decent ground to the plug from someplace. I wouldn't hold the plug in your hand or you could get a surprise :). If you are not going to check the timing at the same time in the inspection opening, then there's no need to pull all plugs, just any one on them to only check for spark. Just remember that there are only two mag snaps (plug fires) per crank revolution so depending on where you start you could have three duds before you see a fire. Go through a complete two crank revolutions to be sure.
third party image Rod
