Follow The Wire Lines
Dick L
05-18-2006 05:52:16
lower right shows the resister.
third party image
28sstony
05-18-2006 07:34:31
 Re: Follow The Wire Lines in reply to Dick L, 05-18-2006 05:52:16
That is the same diagram that I was reffering to.
It does not show a third wire coming off of the generator armature going to the resistor/switch.
I looked at another local guy's tractor and there was no wire connected to the armature other than the short one that goes to the cutout.
Is there even supposed to be a wire that goes directly from the armature to the resistor/switch???
From the looks of the diagram I am wondering if the preveous owner had the headlight wire hooked to the armature by mistake.
Dick L
05-18-2006 09:28:21
 Re: Follow The Wire Lines in reply to 28sstony, 05-18-2006 07:34:31
Any wire that is not on the diagram would not be needed for the system to work. I would remove that wire and relocate it if needed for lights or something else. I do not know the condition of your switch but if it were in good condition you would have lugs with screws in them to hook up your lights.
