WD year? clutch parts
Bill in Michiga
05-17-2006 18:39:44
I have been searching but I think I missed something.The number on the rear housing is WD 74123 I cannot find it in the serial list.The number on the engine is WD 280987 GA if that helps.Any suggestions or information would be appreciated greatly!!!!! !! thank's
Bill in Michigan
05-18-2006 19:02:37
 Re: WD year? clutch parts in reply to Bill in Michigan, 05-17-2006 18:39:44
Thank You All!!!!! !! you all have been very helpful thank"s again
Brian G. NY
05-18-2006 14:30:53
The serial #s for '51 start at 072328 and end at 105131; that makes your tractor an early '51.
Brian G. NY
05-18-2006 14:38:02
 Re: WD year? clutch parts in reply to Brian G. NY, 05-18-2006 14:30:53
The "201" was the only engine offered in the WD. A newer style (tall) head was introduced on the WD with tractor serial #WD289001. This head was continued on the WD-45 "226" engines. The "226" engine was introduced with the WD-45 in 1953 with tractor serial #WD146607.
Larry in Michigan
05-17-2006 19:12:27
The number on the rear housing makes it a 1951. The gear shift lever should be straight not curved.
Bill from Michigan
05-18-2006 06:02:38
 Re: WD year? clutch parts in reply to Larry in Michigan, 05-17-2006 19:12:27
Yes the shift lever is straight.Did they only make 1 motor for that year? Do you know why I can not find serial no. in searches? Thank's again for all your help.
Aaron SEIA
05-18-2006 16:40:23
 Re: WD year? clutch parts in reply to Bill from Michigan, 05-18-2006 06:02:38
Not sure why you can't fint it. It's listed on this web site, I linked to it. They only made one engine for the entire run of WD's and one for the very very late WD's and all the WD 45's. Just did some poking around and a couple of parts places on-line list one clutch for any WD or WD45.
Aaron SEIA
