alcohol fuel
crystal allis
05-15-2006 22:24:23
i was wondering what it would take to burn pure alcohol in my d 17 or wd or if it would run to hot to bother with
Kent of SW MO
05-16-2006 06:47:37
 Re: alcohol fuel in reply to crystal allis, 05-15-2006 22:24:23
Which alcohol? Ethanol, Methanol The first one has 75% the heat of gasoline. youwill use more. The second has 66% the heat of gasoline You will use even more. The second is also VERY had to start at temp below 45 degree F. You cn modify the carb to do it. This increase in fuel usage of so called renewable fuels is going to surprise MANY people in the coming years.
Kent
TexasAllis
05-16-2006 05:51:38
You can run alcohol on just about any combustion engine. They actally run cooler. They question is why run alcohol. If you are pulling I can see using it. For everyday use no way. You will burn twice as much alcohol as gas. Alcohol is more expensive and you need to make serious modifications to your carb to run right.
ohio
05-17-2006 10:41:56
 Re: alcohol fuel in reply to TexasAllis, 05-16-2006 05:51:38
about 1.5 times as much. (ethanol) you could run c.r. as high as you want, and in five years, everybody will be running it. (e85) smells good, too. if you are making it, it is less than a buck a gallon, until corn goes up!
