ac 7080 fuel filter pump upgrade
jim ball
05-15-2006 11:40:14
i have an early 7080 with two glass filters.
the fuel is sucked up by injection pump so i am told. i want to put on spin on filters and add
an electric fuel lift pump. parts manual shows a
stanadyne upgrade. anyone have any experience ? i live on a hillside farm and am sensitive to level of fuel in tank and am subject to cold weather starts & spin on works easier & is less expensive.
txs -- jim
Hurst
05-16-2006 19:18:58
 Re: ac 7080 fuel filter pump upgrade in reply to jim ball, 05-15-2006 11:40:14
I also think that the pump needs to be adjusted for the added pressure a lift pump will feed it. The pump will need to be set to recieve this pressure instead of sucking up the fuel from the filter body. Good luck
Hurst
Bob
05-15-2006 19:35:54
I recently worked on a neighbors' 7060 with the kit installed.
It is a electric vane-type transfer pump feeding a spin-on filter.
If Agco can't help you, you should be able to find a pump rated for diesel fuel, and a filter supplier such as WIX or Bladwin will have a filter/base kit.
856 puller
05-16-2006 15:10:17
 Re: ac 7080 fuel filter pump upgrade in reply to Bob, 05-15-2006 19:35:54
you might want to check your local diesel pump reibuild shop also. the one i deal with handles filter heads and transfer pumps and technical help is first rate
