B oil filter
maricopa
05-14-2006 10:27:37
Okay, here's a really silly question. The dowell in the new oil filter is only there to center filter element, right?? It comes out before filter goes on, right??? Pardon the newby question, never had this type element before. I removed filter after running and filter is full, but not running out of filter.
Was wondering, cuz, I have low oil pressure now. Gonna flush engine oil and then replace with 20-50, new filter and oil treatment. Sound like the right thing to do????
Bob
05-14-2006 23:22:44
 Re: B oil filter in reply to maricopa, 05-14-2006 10:27:37
Your filter base does have the metal tube sticking up that enters the hole in the filter you've just pulled the stick out of, right?
(Sometimes they come loose in the filter base, stick in the filter, and get thrown away with the old filter.)
The tube is rolled almost shut at the top, and restricts the oil flowing into the filter.
steve(ill)
05-14-2006 16:00:56
put a FRAM 159 and check that. 90% of the WIX or NAPA filters cause problems.
old
05-14-2006 12:11:54
Some brands of filter don't work well and will cause low oil preassure on your tractor.
maricopa
05-14-2006 10:37:34
Thanks Kip. That's what I did. Just concerned about the low oil pressure. Do you think brand of filter matters (AC delco vs Fram vs Wix)?
klf
05-14-2006 16:00:22
 Re: B oil filter in reply to maricopa, 05-14-2006 10:37:34
The AC Delco and Wix filters are good, but I don't think the Fram filters are worth a darn. Hastings and Fleet Guard are good filters too.
Kip[UT]
05-14-2006 10:33:49
pull the stick out & toss it.
