Blue Smoke Rollin 2
cheatmtn
05-14-2006 07:41:44
Spent some time on the tractor yesterday...heres what I have found so far. The coolant level stays up when running. The oil is now a darker brown (was clear when we started, but is definately darker now from running it) Does not appear to have fuel in the oil...no diesel smell. We did take off the crank case vent and found it had a lot of oil in it and appeared pretty gummed up...the manual says take it off once a year and clean with a safe cleaning fluid (what would you suggest?). We also see that someone has hooked up the vent tube so that it runs directly into the muffler and not out onto the ground. A friend told me that it might be acting as a syphon, so we plan to disconnect that. We also found a manifold gasket laying loose in the engine compartment, so we plan to take off the exhaust manifold to see if one is missing or if it was a leftover part that just fell in the wrong place. I also have a question about the oil cap. The one on it has a breather at the top, it is not a sealed cap...it seems to be letting the oil come out of the block and run all over the place. Is this tractor supposed to have one of that type, or a sealed one. The parts manual shows one that seems to be a sealed. Guess I have a lot of questions, but Im not the greatest at tractor mechanics, so any help would be appreciated. Thanks
cheatmtn
05-14-2006 09:54:48
 Re: Blue Smoke Rollin 2 in reply to cheatmtn, 05-14-2006 07:41:44
guess I should have prefaced this with the current issue. I posted about a week ago in ref to my AC 5050 rolling blue smoke out the muffler and a large amount of blow by from under the hood. making it impossible to use the tractor for very long. Sorry for those of you who didn't get to read the first post. Thanks again for any info
