160 won't start
chet-ok
05-12-2006 11:27:07
Hey Guys change feul filter today check for leaks started it than it ran a about a minute than died and now it won't start. air in line? have to break injecter line and breed each one? thank you any help
Chris(WA)
05-13-2006 06:52:01
 Re: 160 won't start in reply to chet-ok, 05-12-2006 11:27:07
Yes you have to bleed from the injector lines back nothing will self prime on that sucker! I have gotten away with only bleeding two injector line and listening to her stumble till the last one catches. STart back at the filters and gravity bleed everything you can first.
Easier to keep the fuel level up. I know the hard way to....
old
05-12-2006 11:28:43
Did you either fill the filter and or bleed the filter before you started it?? If you didn't then you will now have to bleed the whole system.
