trans oil for 200 Allis
North M
05-10-2006 14:08:30
What kind of oil are you supposed to use in a 200 Allis transmission. Just wondering what would be compatable with the power director. Any ideas what is called for in the hydraulics and rear end. I have 15w40 Esso in the moter. Thanks
Hurst
05-11-2006 11:24:22
 Re: trans oil for 200 Allis in reply to North M, 05-10-2006 14:08:30
On my 7000, which is pretty similar to the 200, the tranny/powershift/hydraulics (all one compartment on the 7000, but I think it is seperate for the 200 with a tranny and a powerdirector/hydraulic compartment) and also the differential use allis 821, which is universal hydraulic/trans fluid. The final drives on each side need gear oil. The manual for my 7000 says allis 715 gear lube, which I think is 80w90 gear oil. Hope this helps.
Hurst
TexasAllis
05-11-2006 05:14:52
The Hyd/Trans fluid at most auto and farm stores should do the trick. It should be compatable with Allis power fluid 821. All the fluid I have bought has been compatable. I believe the trans, hydraulics and rear end use the same fluid. If you do not have one get an owners manual and a service manual. They are invaluable.
Good luck
mwert
05-11-2006 05:48:29
 Re: trans oil for 200 Allis in reply to TexasAllis, 05-11-2006 05:14:52
Thanks, I ordered and got a service manual through ITT this winter but cannot locate where to get a owners manual. I bought this tractor last summer at an auction.
