WD Hydraulics
Che
05-09-2006 06:32:46
I'm slowly but surely getting this 1950 WD up to snuff. I appreciate all the good advice.
2 things: First, I replaced the hydraulic rams (old ones were shot and hydraulics were not working). Re-attached everything, filled fluid, and the rams slowly extended to full and are now stuck there. Lever on the dash won't move and the rams are fully extended. Thoughts?
Second: She's running pretty rough again. Pulled out the number 1 and 4 plugs and they looked pretty good. Pulled the 2 and 3 and they were all gunked up - oil and crud. Thoughts?
Again, thanks for any help.
mark finnestad
08-22-2006 20:06:34
 Re: WD Hydraulics in reply to Che, 05-09-2006 06:32:46
regarding your #1: My rams on my 1955 45 also stay in the extended position (they worked fine 2 weeks ago!) My lever works, and and moves the flange where it is attached to the valve assembly. Pump is always on - regardless of lever location - and I am leaking hydro fluid now. Have you received any tips or pointers that might save me some time?
