Hyd. Capacity on WD45
rfdeere
05-08-2006 13:32:26
We"ll I tryed it and it seemed to work O.K. to raise and lower the trailer and a couple of pigs. (50 Lbs. Approx.) Raised it kinda slow. I don"t think it would raise a full load though.
steve(ill)
05-08-2006 16:50:34
 Re: Hyd. Capacity on WD45 in reply to rfdeere, 05-08-2006 13:32:26
the speed should be related to the volumn output, which is low on the WD45. the pressure you put out should be 3200 psi which is probably higher that what the trailer was rated at. i would guess you can lift a full load, but not too fast.
old
05-08-2006 13:43:21
Depending on what type of hitch you have, I.E. 3 point or snap type. But either way you should have enough hyds to lift the front end right off the ground.
