Allis fuel lines
john morris
05-08-2006 06:16:46
Can anybody explain how to pipe up a fuel system on an allis series b, mine has just one supply from the gas tank direct to the carb, the TVO tank has been excluded,there must be a way of switching from gas to TVO, does both feeds go first to the glass filter bowl ??
Kent of SW MO
05-08-2006 07:23:22
 Re: Allis fuel lines in reply to john morris, 05-08-2006 06:16:46
Whats a TVO tank? I work for an Allis dealer for a few years and do not know the term.
Kent
john morris
05-08-2006 07:41:40
 Re: Allis fuel lines in reply to Kent of SW MO, 05-08-2006 07:23:22
Tractor vaporizing oil, at least thats what it is called in the u.k dont know what you would call it Parifin may be ?? you can make it by mixing diesel, petrol (gas) and oil, if you look it up on the net you will find it.
Kent of SW MO
05-08-2006 10:36:17
 Re: Allis fuel lines in reply to john morris, 05-08-2006 07:41:40
Here in the states the small fuel tank was used for gasoline to start and warm the engine while the main fuel tank was filled with Distillate, also known as tractor fuel.
Kent
john Morris
05-09-2006 00:20:29
 Re: Allis fuel lines in reply to Kent of SW MO, 05-08-2006 10:36:17
Thanks for that Kent.
Your quite right, we British call it TVO and you Americans call it Distilate.
Now what I need is a diagrame of the piping layout from both tanks to the carb.
