WD gaskets
Justin Squire
05-07-2006 08:54:37
I purchased a full gasket set for my WD and I did not take time to check if they all fit because I figured they would. I had already used several gaskets when I got to the engine head gasket. It was obviously too small and I had already coated it with copper sealant before I realized this. I also realized that the oil pan gasket was much too small. I think these are the only gaskets that don't fit. I don't think I can return the set now. Can I order these two gaskets separately from this website? The problem might be because I have a late WD with the curved shifter. It probably needs the WD45 gaskets doesn't it? Any help would be appreciated.
Butch(OH)
05-09-2006 08:34:27
 Re: WD gaskets in reply to Justin Squire, 05-07-2006 08:54:37
WD and 45 use same gasket set, you were sold wrong parts.
napaguy
05-07-2006 19:16:32
hi justin, why do you think your tractor is a wd? i thought all curved shifters were wd45s. i think you can get a separate head gasket and oil pan set. i got a guy a valve cover gasket for a 45 last week. napaguy
Justin Squire
05-08-2006 07:57:08
 Re: WD gaskets in reply to napaguy, 05-07-2006 19:16:32
I know mine is a late WD from the serial number. I have already researched that.
JMS/MN
05-08-2006 06:58:50
WD45 started at 146007. but the constant mesh tranny was used earlier on the WD, starting at 127008 in 1952. Angle cut instead of straight cut gears, curved shifter. Shift levers do not interchange, but the towers do. Later towers have a second guide pin for the shifter ball, but that can be drilled out on the older tower to use it on a WD45.
AaronSEIA
05-07-2006 11:02:18
Seems odd that everything would work but the head and pan. They were the same from the mid WC's through the end of the 45's, so it shouldn't make a difference. I know you could get them seperate from an AGCO dealer and maybe an auto parts store.
Aaron SEIA
