WD running problem
Rholt
05-07-2006 05:14:01
I have a WD and a WD 45. Both start and run fine until they are warmed up. Quite often they will start to die out unless I pull out the choke for a short time. Then they run fine again for a few minutes. Some times they run fine for an hour or more.
Will Herring
05-07-2006 18:43:11
 Re: WD running problem in reply to Rholt, 05-07-2006 05:14:01
I only do this if I'm on the tractor and I'm going along and it starts to die on me, but I pull the choke once and let it back in and it usually blows the crap out of the engine.
old
05-07-2006 14:19:27
You probably have some junk in the carb/fuel system. Theres 2 ways to fix/get around the problem. One is to rebuild the carb and clean the fuel system, which you probably don't need to do. The other and this works most of the time is. Start it and with the air cleaner tube off put your hand over the air intake and then take it off fast to keep from killing the engine. Do that 4 or 5 times. What that does is causes the engine to suck the junk out of the carb and open up the clogged parts of the carb. If that doesn't work you will need to go back to what I said first
gene (missouri)
05-07-2006 08:14:01
Fuel supply problem. Suggest blowing out the fuel line, cleaning the sediment bowl and fuel tank.
Gene
